- Joined
- 25 Apr 2023
- Messages
- 9,352
- Reaction score
- 6,422
- Country
Was thinking about when people ask how to connect a light and they have 3 twins and the switch wire isn’t labelled on the switch cable.
The question is asked if they have a continuity tester, if they do great....but if they dont what do we think of this?
Put the 3 pairs (reds and blacks) into separate connector blocks. (6 connectors)
Remove one wire from the switch and put into a connector block.
Put any 2 sets of red and blacks together red to red black to black.
Turn the power on and check if all the lights work in the house, rotate the sets until they do, (turning the power off each time) when they do the set not being used will be the switch drop cable?
Thoughts?
Thoughts?
