Mower veers to the right
Bonus.....go for something like this...
It sounds like the right hand wheel isn't being driven so check for the drive dogs missing or the wrong way round.
If you can spin the small pinion on the axle in both directions, that's the clue. The pinion should freewheel in one direction and grip in the other.
John
I advised I’ve removed the internal cogs / gears so now wheel just rotates on the shaft. It’s now a push mower.
Is the blade at the same height on both sides inside the deck
If the blade was a different height wouldn’t the grass Ive cut also be a different angle because it looks flat to the ground. It’s not giving any signs as if mower is cutting a slope.
The axle is just a shaft going left to right with a couple of springs.
When mower is on the floor I don’t see it bigger one side to the other so I would say this is ok.
If a springs seized could force it over.
Is the distance between the front wheel and the back wheel the same on each side?
Today ive done the following but still the same so may just have to put up with it.
Removed all wheels & lubed up each wheel & replaced.
Removed height adjuster bar front rear left wheel to front left wheel.
Theres no bush as such on rear wheels but just a triangle piece of bracket with a hub shaft that passes through the plastic backplate.
Wheel goes on with washer & nut, spins free with no drag at all.
Yet still it veers to the right.
The deck/frame must have a twist then if wheels have been swapped, tracking is correct its the only possibility left.
You asked to tip up mower on front then rear of which i did but veer wasnt there until i put all 4 wheels on the floor.
Can you exaplane / whats happening there then
