12V Halogen Downlights outside
21 Aug 2007
Oxfordshire
Hi guys I would appreciate a few pointers here.
I am planning to fit a row of 5 halogen downlights at the front of my house connected to a PIR sensor.
Do I need to fit IP44 or IP65 downlights ? A friend has told me I need neither and just to fit normal ones but I'm not so sure about this. They are quite well hidden under the soffits of the house and won't be battered by rain but surely they must need to have some kind of moisture resistance if they will be outdoors ?
Also, should I pick lights which have an individual tranny feeding each bulb or can I get one with 5 plug in sockets which can feed all 5 bulbs ?
Thanks in advance for any tips.
Davie
Why use 12 volt ones? Use mains voltage and fit LED lamps. As these will be mainly decorative colour rendition and brightness wont really matter so LEDs are perfect. :D Oh, and its less to go wrong and LEDs use 2 watts per lamp.
I have a feeling it might as he's using a PIR to control them.
Time for some CFL's? :wink:
I'll be fitting 6 x 7watt CFL's at the front of my house but will be using IPX4 shower style downlights with a white bezzel.
1. He wont need a PIR with LEDs. He could leave them on all year round and only have about £2 on his lectric bill.
2. GU10 CFLs take about 4 mins to reach full brightness. Are you sure you want them on a PIR?
No, they'll be controlled by a dusk/dawn sensor with a timeclock thrown in to maintain more control eg on at dusk, off at 10pm.
An overide switch will also be fitted in the porch.
What is a CFL ? :?
I will be using them to illuminate a dark path on the approach to my house. I only want them coming on when someone approaches, not burning away 24hrs a day.
IP44 or IP65 ?
Or are there LED lights which would be as bright as a halogen ?
Ducati Rider said:
What is a CFL ? :?
IP44 or IP65 ?
CFL - Compact Fluorescent Lamp
IP44 is good enough for outside under a soffit.
I doubt you'll find any LED light to match the output of a halogen lamp.
Cheers :D
Last question......if I buy them with an individual transformer per light, how do I wire these ? Can I put all 5 transformer wires back into 1 chocbox to supply the power ?
Or would I better going for 1 big transformer to feed all 5 lights ?
I would personally use 5 transformers with each one located by the fitting it controls.
240v would be looped to each transformer with the connection being made in a small 20A 4 terminal junction box.
