Hello to you all and Merry Christmas first of all. I'm hoping the Christmas days after-celebrations boredom will provide me with some answers
Before I start I appreciate everyone will advise me to call an electrician and have it done by them. This is what I might do unless it's a very simple solution but even if I have to call an electrician I need to know exactly what I need to get done. In my experience the more tradesmen I call the more options and opinions I get for the same problem. Also I have searched the forum for answers but could not find one.
So here is my question:
We are doing our house up refurbishing everything from top to bottom. This involved the whole house being rewired. It has been done by a qualified electrician all certified and legal.
When he wired our oven because of my stubbornness we used a grid switch for all the kitchen appliances. I did not want unsightly switches all around the kitchen wall. Long story short what I have installed from the consumer unit (sorry if I'm not using the right terms I am not a qualified electrician) 16A RCBO, then 6mm2 cable to the grid switch. The grid switch is 20A MK switch. From the grid switch 2.5 mm2 cable to a 13 amp regular socket. As far as I understood the electrician said he had to install the socket instead of an FCU so that in the future no one can connect a larger than 13 amps oven to the wiring. I was ok with it because that time we wanted to install a small 13 amp oven to it so I said it's fine. As it happens now we have changed our mind and found quite a few nice 16 amp ovens.
Question is what is the easiest safe and legal way to connect a 16 amp oven to this setup.
Any help or advice is much appreciated. Thanks
