I’m looking to run some lighting cables and it would be helpful to run to the switch first then on to the light fitting (breaking the live at the switch)
That way no joint boxes and only one cable at the fitting.
My question is I would end up with around 6 1mm T&E at the CU would it be ok to connect 2 sets of 3 to two MCB’s or run them all into a joint box 1st.
(Is there a maximum amount of cables that should terminate in a MCB.)?
