I have four 2 amp sockets in the living room, as the plugs are un fused, should there be some supplementary protection other than the MCB?
Thanks.
Thanks.
Thanks for link to fused version as long as no unfused versions are used that would cure the problem as to 2A on a 6A lighting circuit but personally I would still not fit 2A sockets as the unfused versions are so readily available.
The old version was designed so fused one would fit standard socket but unfused would not fit socket designed for fused plug.
As others have said, I'm sure that 2A plugs are seriously over-engineered, and I would personally be very happy for them to be protected by a 6A MCB and, indeed, to carry an in-service current a lot more than 2A.I would question the idea of a 2A plug protected by 6A MCB
I did begin and thought they may be alright on a 32A circuit - especially a spur but of course they would be pointless as a 'normal' 13A socket could be used.I'm surprised someone hasn't pointed out, OPDs are theoretically there to protect the cables, not the accessories
Quite so. As you say, I can't really see what would be the point.I did begin and thought they may be alright on a 32A circuit - especially a spur but of course they would be pointless as a 'normal' 13A socket could be used. ... Overload would be all but impossible with just some lamps (or a clock).I'm surprised someone hasn't pointed out, OPDs are theoretically there to protect the cables, not the accessories
Indeed - a very good question. I would imagine that it would be difficult or impossible to design a plug of that physical size (and with the pin/terminal sizes they have) which couldn't happily cope with a lot more than 2A!Then I wondered why there is such a thing, 2A socket that is. To be on a 6A circuit why not make them 6A. The pin contacts must surely be a fair size to match the plug pins and how small can the terminals be?
I do see where 5A or 6A can be classed the same so for example a 5A ceiling rose is protected by a 6A MCB but in the same way as you point out a normal 13A plug and socket can be used there is also a 5A version of the round pin plug they are made in 2, 5, and 15 amp versions so I can see little point in using a 2A version on a 6A supply.I did begin and thought they may be alright on a 32A circuit - especially a spur but of course they would be pointless as a 'normal' 13A socket could be used.I'm surprised someone hasn't pointed out, OPDs are theoretically there to protect the cables, not the accessories
... but is that significantly different from saying that someone could connect 1.0mm², 0.75mm² or 0.5mm² flex to a 13A plug with a 13A fuse in it?... clearly there would be no problem using 0.5 mm² cable with a 2A plug it's rated at 3A so well within the requirement. However when used in a socket protected by a 6A MCB then there is a danger that the cable could be overloaded.
