cos you can use it on the dirtiest ****tiest pipe and it will clean it and run the solder (invaluable when you are dealing with copper methusala installed
but should not be used on gas as it will erode the copper eventually (this is the same reason we can no longer use soapy water for leak detection) where as non active flux will not
well done on wiping down, not many people do it, as I said dont worry about it
some will disagree but how the heck is anyone going to know if you did use active stuff?
I dont think you did actually if i remeber the numbers right.
