9800 re-setup - PIR problems
14 Jun 2016
I've reconfigured this old Scantronics 9800 system following a system reset, having been unused for a few years.
On a walk test - 3 of the PIRs illuminate OK ... but they don't set off the sounder.
These 3 circuits are setup as AL (normal alarm).
The 4th PIR works fine - this is setup as an Entry Route.
The door contacts and panic buttons also work OK.
All PIRs are original from 1990 (Pyronix Magnums, I believe).
Could I have missed something on the setup or might the PIRs just be past their use-by date?! (All 4 of them are a bit sluggish and hit-and-miss at lighting up, also staying lit for a couple of minutes after I've left the room).
Appreciate any pointers. Thanks!
Put a multimeter on the alarm relay terminals on the PIRs to ensure the relay is opening & closing. Check voltage is between 12-13v & check that no + voltage is on the alarm loop. Make sure your alarm & tamper loops are wired in correctly. Simulate a open circuit in the panel by removing the alarm loop wires & see if it trips in walk test. Tbh new PIRs are very cheap & look better too i would change them to reduce the chance of any false alarms.
Thanks guys.
I'll probably get a professional in for that.
For my info, what PIR would you recommend? A pet friendly one, would be good (that's why we stopped using it for a while).
What would be a reasonable ballpark cost for replacing 4 PIRs (Reading, Berkshire area).
(I appreciate, with such an old system, costs might then escalate!)
Bosch tritec
What's the pet and how big?
Also depends where the pirs are sited?
Not good looking at stairs and near worktops / tables etc for pet sensors
Cats for now but possibly a dog sometime.
Yes, one PIR is at bottom of stairs and catches anything in hallway..or going up/down stairs. Another is on the landing at top of stairs.
The PIR would need to be clever enough to ignore certain body masses, even if they came in range - on chairs table-tops etc.
Bosch Tritec or Texecom PW detectors are very good, prices available online. Labour variable!
They work on body heat mass, i think usually between 15kg & 40kg specs differ from detector to detector.
Sounds good. Thanks for all your help. Good stuff!
Now to find a trusty professional. Any recommended specialist websites?...or is it a case of Checkatrade etc?
Nsi or Ssaib registered installers are all insurance approved. Look on website for installer in your area.
