I expect whoever installed the panel, changed the engineers code, so unless you can get hold/find it, then you need to reset the panel, and then reprogram the system.
Unless you're prepared to start at 9999, and then work backwards to see if you can find it yourself. Which is the lesser of the 2 evils.
