Additional boiler to outbuilding
7 Oct 2013
Hampshire
Hello,
Am getting new outbuilding (about 25M away from the main building) built. I would like to take gas and water to the outbuilding.
My question concerns is would our current meter/gas pressure could support additional boiler (hot water/heating) or we need to consider upgrading the gas supply/meter?
My current boiler is Valliant ecotec 630 and we also have gas oven/cooker.
Thanks in advance.
You'll need to get a GSR engineer in to do a few observations, measurements and calculations to see if your current supply & meter is adequately sized. Not something that could be advised without being on-site.
thanks, Madrab, will consider this, is there way to find out average household gas pressure can support in KW?
Several factors can determine this and some of these are determined locally by your transporter, what meter you have, supply pipe size/pressure etc. These can vary significantly from location to location. Without certain information it would be a wild guess, which will not be what you need.
I understand the need to get a basic picture but unfortunately there are too many variables to give even a ball park figure, hence the need for an on-site visit.
OK great, would getting SG1 servy done help to get the required variables/parameters?
Yup, that would give your GSR engineer a starting point with a new service.
That being said, a good GSR engineer should be able to calculate capacity and if current installation it suitable for what you wish to do from what is currently installed (referring to actions performed in my 1st post).
GT1 Survey requsted, results expected next week. BTW when the report comes what parameters i need to look out?
Cheers
I really do think that you would be better engaging a local RGI to assist you who can visit the site.
Ignoring the size of gas pipe to the outbuilding you will probably be able to have a smaller heat only boiler within your existing supply constraints.
Even if it is not suitable I would expect that ( at a cost ) you would be able to have a new supply and pay the standing charges.
But have you really though why you particularly want gas there?
What have you got against the cheaper option of using electricity?
Tony
A GT1 survey will only tell you what the main is capable of delivering.
You need RGI in to calculate what you have at the moment (meter, appliances & pipework) and then add in what you want (extra pipework and appliance) and then confirm whether your current meter/supply/pipework will be suitable or if and what you'll need to upgrade.
Tony
Thanks Tony
What size smaller heat only boiler?
Did not realise that it would be simpler and cost effective to have a new supply and pay the standing charges.
Gas there so we can have CH and ho shower Shower facility.
Nothing against leccy, dont think electricity cheaper option.
I guess that was the intention at the outset, available vs requirement, we know the requirement, 24KW boiler, enough to serve additional CH/HW requirements.
You can have electric space heating and an electrically heater cylinder for water.
Why do you think you need a 24 kW gas boiler?
I didn't think i needed 24KW boiler, i was advised by the plumber/HE that i need 24KW boiler.
Is there a way to work out gas vs electric cost effectiveness?
