Apologies on the potty mouth i had been on the syrup
apology accepted
but i stand by my principles that your advice is often tainted with self indulgence or pompous attitude generally that said i believe you have advice to offer albeit full of arrogance.
I assure you that is not my intention, even if it may seem that I come across that way to you. My friends & family would be surprised that a statement like that would be addressed to me (Unless you talked to the missus that is
but shes a funny bloke!). I am firm but fair, but not arrogant, self indulgent or pompous.
I am just trying to get a message across to you and other readers that may browse this topic for related help, with regards to safety.
I don't declare to be a get author of posts, so may be you are misinterpreting my posts, thinking that I have some sort of agenda to pyss you off! That is not the case, otherwise I would tell you straight and offer no guidance what so ever!
Two cables from consumer unit running to bedroom stops at a 30a junction box then another two cables go to 1st socket another cable from socket to 2nd socket and another cable to 3rd socket. Then two cables go back to junction box. There is also a spur from 2nd socket going to a fused spur powering a tv.
I will have to dissect the above information
*Two cables as a ring or two radials?
*Two cables to a one JB or to two?
*Two cables to first socket from junction box, a little puzzled by that, not sure what you are trying to achieve, does not sound right or normal.
*Second and third socket added as an unfused spur from first socket, again would need to know why you have run two cables originally to first socket as it would seem your intentions would be to run a ring, but that would mean you cannot spur from a spur.
I think a radial would have been a more suitable selection of circuit.
*Also the sizing of this cable and method of which was installed would be a design consideration
I have taken the 16a mcb that supplied the electrical heaters and run two cables from it into the loft and terminated into two 13a double sockets.
Is this a different circuit to the above?
