I'm just planning a kitchen for a refurb job in a property which I will eventually be renting out and I seem to recall some restriction regarding fitting a gas hob or gas cooker close to an openable window. I am intending putting in both a gas and electric supply for the appliance so that the tenant can make their own choice concerning the appliance type but, I obviously need to have the gas and electric supplies put in local to where it will be located.
Does anyone know the current up to date ruling on how far a gas hob or cooker needs to be away from an openable window and is this distance measured form the edge of the opener or from the edge of the window frame itself?
The type of cooker that would be installed would be as the link below:-
http://www.argos.co.uk/static/Produ...cip=35948.Cookers>C$cip=35954.Gas+cookers.htm
Also, does this sort of appliance need to be a certain distance away from the worktop edge or can this be fitted tight upto the worktop as long as the worktop edge has a metal edging strip screwed to it?
Any advice would be very much appreciated. Thanks.
