Our CH runs 24/7
Our CH runs 24/7
Yea but the pump should only be running when the boiler fires - so shouldn’t be running 24/7. If the pump runs irrespective of whether the boiler has fired or not is your main issue, not cheap pumpsYes every day, 24/7/365 - In the summer the temperature rarely dips enough to trigger the thermostat, but it is on - just in case.
The Other Half is very temperature sensitive...
Ok, the pump only comes on when the boiler fires < my point was that I thought we had got through a lot of pumps and valves because my CH was on more often than the standard household - rather than us buying cheap pumps and/or valves.Yea but the pump should only be running when the boiler fires - so shouldn’t be running 24/7. If the pump runs irrespective of whether the boiler has fired or not is your main issue, not cheap pumps
Probably not that often, but loose plugs do often make things easier. While it might not be complicated, wiring to the terminals on a pump when it's in-situ is often "less easy than it could be" since the pump will have been positioned for ease of plumbing and not ease of wiring. And often, it won't be practical to wire the pump beforehand - cable too short to let pump rest on convenient surface while wiring and before installing in the pipework.Just how often do you find yourself swapping out faulty pumps, valves, stats etc?
