Hi all.
I have some new MDF skirting and architrave that I need a satinwood finish on. It was pre-primed but I put on a coat of wood primer/undercoat as well which was a bit thick but seem to have gone on well enough (I only realised afterwards you're not really meant to use it on MDF).
I have an old tin of Crown quick drying Satin paint, but I'm not convinced of it's durability. I know waterbased satin paint is not reknowned for having a hard wearing surface but this isn't good enough. A hard scrape of a fingernail is enough to scrape it off so it's not going to withstand hoovering/sweeping/kicks etc.
Does anyone know of a hardwearing waterbased satin for wood? I have heard of Dulux Trade Diamond Satinwood, which is apparently hardwearing, what are people's thoughts on this? Any thoughts on the durability/chip resistance of Sikkens BL Satura?
Are there any other ones that are worth trying?
Also, Dulux Decorator Centres, are these places open to the public? Can I just walk in and get something or do I need to have an account or something?
Thanks.
Appreciate any help
EDIT: Also, for filling the screw holes, what should I use? Could I seal the hole with PVA and use a regular filler or should I go with a two-part filler? if so, is there a good one anyone can recommend? What about caulking the top gap against the wall....what should I use for that?
Thanks.
Appreciate any help
