We had a bathroom leak a week ago. An emergency plumber came out. He found that one of the plastic tap joints had been over-tightened. The copper ring caused a crack in the plastic joint. It had been like that for 10-11 years (since we bought the house). Thankfully we caught it while it was still a drip. The plumber fitted a new plastic joint (seems to be heavier duty).
We can see a damp patch under the bath, below the tap fitting. The tap fitting is on the side of the bath, rather than at the top of the bath. A week has passed - the damp patch seems to be drying up (shrinking and does not feel wet to touch). We are not using the bathroom.
However, when we removed the tiling on the side of the bath to get access, we found a second damp patch. This damp patch is at the top of the bath, under the plug hole / trap. The plumber did some tests, but wasn't sure what was causing the second patch. He checked all the pipework and said that he thought everything was good. He suspected that old sealant around the side of the bath was the culprit.
A week on, the second patch has not dried out. It still feels damp to the touch. We haven't used the bath. I left a piece of kitchen paper under the trap for good measure, it was not wet at the end of the week. I have no idea what could be causing the second damp patch. Could anybody help with any suggestions for things to check?
