Be honest - How many Pro Sparks here ALWAYS do this?
11 Jan 2004
I always lock off if I am not working near the point of isolation.
Where is your prohibition notice anyway? :lol:
A bit of tape with "Do not switch on" stuck across it although I do have a sign in the van that I can hang on the switch/board if need be with similar wording on it. :D
One I was using the other day in college had been altered from "Danger, men working on equipment", to "Danger, men ****ing on equipment" :lol:
With those switches a long (socket front face attachment) bolt will go all the way through. Spin on two nuts and tighten together. Tag will go over the bolt. Not quite as good as a lock, but always to hand and no keys to lose.
i Lock stuff off all the time, but i would not trust the design of locking attachment show in the picture. I have in the past had a lock and hasp removed and a circuit energised, it resulted in a big bang and some welding. I was not happy but very lucky, the 240mm cable i had isolated and was moving when the end of it exploded :shock:
You wanna sue the cretin that took that off. The thing is, it is obviously there for a reason, and if someone has forced a locked device off a switch, that is crazy.
I always lock off like this, not just for fuseboard changes but any job. I usually attach the dolly lock to the mcb lever.
Or, take out the fuse & pocket it, lock the cabinet lid if it's a MEMERA or similar unit, even lock the cellar or garage (as long as I'm the only one with the key!)
Some companies I know dismiss staff instantly if they have suffered a shock.
there was alot of paperwork after the my moment. It was a tunneling construction site with about 50 men there at the time, the lock (and men working notice) was fitted on a mobile distribution unit which was not in a restricted area. We never found the crim
Also connect the output of the breaker, with a short piece of green and yellow 10mm, to the main earthing bar inside the CU, as well as padlocking it - it prepares it for one of the essential earthing tests you need to do when commissioning the works. :lol: :lol: :lol:
That sounds like a recipie for both unfair dismissal lawsuits (can you prove that the shock was the fault of the person who got shocked) and for people to cover up accidents.
The philosophy is that you are responsible for putting procedures in place to prevent your recieving a shock & therefore if you do, you have not followed those procedures correctly.
I do however accept that in extreme cases, it may be that you have followed procedure, but a scenario like that which happened to jmm could arise.
