boiling a cup off water in a kettle or micro cheap or quick
the cheapest and quickest way to boil a mug off water
  • 900 micro cheapest
    Votes: 0 0.0%
  • 900 micro quickest
    Votes: 0 0.0%
  • 2.3kw kettle cheapest
    Votes: 4 28.6%
  • 2.3kw kettle quickest
    Votes: 10 71.4%
  • Total voters
    14
  • Poll closed .
12 Jul 2004
Surrey
do you think it cheaper to boil a cup in a 900 microwave or kettle
also which is quicker
i have done the maths
posted on another forum
I've seen this before and it had efficiency thrown in too. On that last point the kettle wins in that as a simple electric heater it's nearly 100% efficient whereas a microwave suffers from energy losses producing those microwaves.
Laying aside the practicalities of not all kettles can hold just a cup of water then I believe the kettle wins on speed but possibly the microwave on cost as while not being so efficient it consumes less energy.
thanks i have asked them again
i chose 1 and 4 before doing the test
what 2 numbers would you choose ??
Well thanks, but I was accurately describing squeaky and his post. This is about water boiling and he starts on about the eu.
Just for jbr I'll change it to idiotic comment
ok thanks mods and others
i dont have an induction hob but suspect it may come third but i dont know :D
heres the results
900w micro 20w fan 20w light turntable un known
input wattage 1.5 kw[actually 1486w but to make it simple]heat time 2 mins [actually 2 mins 8 sec]
so around 50w per cup based on 1.5kw per hour divided by 30 at 0.6p per cup
kettle 2.23kwh 1m[1.2sec] so 45w per cup or0.55p at 12p a unit
kettles usually require minimum amounts so unless you choose a kettle that is happy with little or no water over your cup full in a boil it advisable to stick to minimum levels
just to simplify in case my rantings are confusing
the kettle boils in half the time and 10% cheaper assuming exact volumes being used
What exactly have you added to this thread?
Talk about the pot calling the 2.3Kw kettle. :roll:
more than you actually
Only if you count abuse as a contribution.
Anyhow, what's going on, Meachem?
In my first post on the link below, I replied to you as peter meachem ,but bizarrely your name has now changed to wkdhd, and now sounds more like an American radio station name.
http://www.diynot.com/diy/threads/african-american.419919/page-4#3261216
Now, you've re-appeared with a different suffix to your name. Still posting the same garbage though. :lol:
So, who are you? A Mod up to no good? Surely only admin can change user names?
We'll get confirmation if you are a Mod, because this post will rapidly disappear.
