Ah. Fair enough.
It is not wrong though, there is nothing excluding FCU from being on 6Amp, 10amp or 16Amp circuits.
Do I take it that you know that when these items are sold outside of the UK, the instructions (in whatever language) 'ask for' an FCU?What is wrong is asking for something that is not available or compliant in much of the EU.
Kind Regards, John
In view of what you go on to say, does that 'No' mean 'Yes'? (or is your true answer 'No', but you're guessing that it might be 'Yes'?)!
Not having ever bought electrical items outside of the UK, I personally haven't a clue what instructions they come with, so I can't argue with someone who apparently has such experience.Normally items are sold with instructions in multiple languages. Sometimes there is an *, saying something about how to wire a plug in the UK, but I've never seen anything saying FCUs only in the UK.
The French rarely use fused plugs, does that mean we should not use fused plugs???????What is wrong is asking for something that is not available or compliant in much of the EU.
Many boilers have related external components such as motorised valves, thermostats, programmers etc which are supplied direct from the FCU and wouldn't be protected by the boilers internal fuses.on a 3A FCU, boiler has internal fuses so is it really necessary?
Get a grip man, FCUs are not wrong!!!
Do you really use German, French or Polish wiring regulation when installing an electrical system in the UK and source your material from mainland Europe? I doubt you do!!!!
And would you refuse to install a FCU because you can not source one from a French or German wholesalers?
So you would think, but very few programmers have internal protection. Nor do motorised valves, and they come complete with 5 core fly-lead, the conductors of which have a low cross-sectional area.But these items like all electrical devices should have their own internal protection. The function of an external fuse is to protect the cable.
Which is why most table lamps and hand held appliances have to to have flexible leads rated at 16 amps, only they are not as flexible as a lead rated at 5 amps protected by a 3 amp fuse in the plug.The French don't used fused plugs as they don't have 32 amp ring circuits. We wouldn't need them if our circuits were 16 amp radials.
wondering why it has not been passed and having to remove it.
Yes, but we are talking (still, I think) about 6A circuits requiring fusing down.So you would think, but very few programmers have internal protection. Nor do motorised valves, and they come complete with 5 core fly-lead, the conductors of which have a low cross-sectional area.
Yes, I think we are still meant to be talking about that, and I agree that it's a bit silly. Even though I don't doubt that bernard will probably remind us that "double the power means 4 times the ('explosive') power", in the context we're talking about, I really don't think that the difference between 6A and 3A is of any real consequence.Yes, but we are talking (still, I think) about 6A circuits requiring fusing down.
I would not imagine that the little motors in MVs etc. could result in an overload (rather than fault) current which was very high, but I'm not sure what the stalled current of a circulator pump would be.What is the possible overload that could be created by a synchronous motor or even an external pump?
Anyway, what do they do in Europe when fitting a boiler and associated parts to their 16A circuits?
