I'm having problems with my heating system, hot water seems to be ok but heating will only work with the hot water on as well, i'm wondering if one of the 2 port valves might be at fault, but can't understand the lever set up on them, the lever seems to have little resistance in its normal position, more resistance is felt as the lever is moved towards "open" but it will not stay in this position.
Is there anyway i can override the motor to check its functioning, not sure if these valves can be dismantled to replace head or motor. Any help much appreciated
