Brit gas trying to kill a customer
14 Jul 2009
Bedfordshire
Have vent size changed in the last year, reason why I ask a old lady of 84years old over road to me had her back boiler serviced by brit gas he said regs had changed and turned boiler of due to vent being to small, the size was 9 inches by 6 inches. The boiler had been serviced by brit gas for the last 15 years, the temp outside was - 7 was he trying to kill her.
So I change vent cover and make vent larger wot is 100cm squared in inches, the largest gas vent grill at b& q is 9inches by 9 inches.
By the way I did turn her boiler on, Yes i did say it was minus 7
BG serviced my boiler this year, an Ideal Mexico. It is in a cupboard with a partition in that has two airvents in, then a door on the cupboard with two more vents in.
He did not turn me off, but said it was NTCS. Maybe her boiler was different and the ventilation was safety critical? Don't know.
Hope you carried out all the other safety checks that would be required following a disconnect.
You might have done better to give her an electric fire and then raise a complaint.
Johnsmiley, what is the relevance of vent size (9x6 or 9x9)?
You have now taken responsibility for the job, and it appears you don't know what you're doing.
Was told by sevice person the only thing wrong was vent size after he had service boiler, no label was put on boiler he had run out of them .
There was a reason why asking when regs changed vent size, or does no one no
more concerning is that you dont seem to know the current vent regs and you have turned the boiler back on, therefore if anything happens to the lovely old dear "you are doing a favour" you will get slapped for it
And now you have been monkeying around with the ventilation you have a duty of care to ensure the flue is operating properly FFS.
This is why you shouldn't have got involved.
