Hi all,
I have a plain and simple 100w max light fitting in a spare room. I am just about to renovate it to be a nursery so thought it would be a good time to install a dimmer switch.
The fitting originally had a 100w bulb which I found hummed a lot. After some googling I found this was not unusual and could be resolved by using a lower watt bulb or by trying a 'rough service' bulb that has a thicker filament and less prone to vibration which makes the humming.
After some hunting around the house I found a 60w rough service bulb and gave this a try. It resolved the humming perfectly, but I found it to be a bit dreary in the room so wanted to try a 100w rough service bulb.
I order a 100w rough service bulb and just tried it and although there was a little bit of humming at certain levels of dimness, it was much better. However, after 5 minutes or so I could smell burning and noticed that the bulb had actually partially melted the plastic on the light fitting.
I did notice that the new 100w bulb did seem exceptionally bright. I am sure it was brighter than the previous non rough service 100w bulb I had before installing the dimmer switch.
What is going on here? Did I get a bad bulb? Or is the dimmer switch not compatible and is somehow suppling more power than it is supposed to?
