Morning all i changed the ceiling light yesterday the old fixture had alive and earth connections but also had 2 black wires i assume the are neuteral wires, the new fitting only has a connection for 1 of these black wires can i connect the 2 together,
I have to say that it's a bit worrying that you wondered even briefly if you could connect 2 wires together that weren't connected together before.
One of those blacks is a live, not a neutral. I hope you made a note of which was which - if not you're now going to need a multimeter to identify them. Get it wrong and you'll create a short circuit which will blow the fuse/trip the MCB and quite possibly wreck the switch.
