Change Thermostat - Sunvic TLX9201 to Salus RT300
26 Apr 2019
I want to change my room thermostat from Sunvic TLX9201 to Salus RT300 but want to check the wiring before I do so.
There are currently four wires coming out the wall. Blue + 2x Brown connected to the thermostat and the Green/Yellow connected to the back box.
Can someone help me confirm which goes where on the new thermostat? Images below.
Thanks!
Sunvic (Exsiting):
Salus (New):
Not sure you should be touching electrics if you don’t know the wiring colours, did you safely isolate that before removing or was it still “live”?
Currently:
You have a brown live
Black switched live (sleeved brown)
Grey (sleeved blue) which may be acting as a neutral
Earth (green/yellow)
On new:
Live (brown)
Switched live (black - sleeved brown)
Park your earth
Neutral would need to go in a connector block/wago
Please only work on electrics if you’re competent
Not a very helpful reply to someones first post.
I might not be an electrical master, but I'm perfectly aware which colour is which. I'll make sure I write the types next time instead. And yes, I did have the common sense to isolate it first.
I personally don’t see how it’s unhelpful, I’ve answered where your wires should be going, I’m just making sure you don’t injure yourself or worse - actually trying to be helpful, but ensuring safety is paramount. o_O
Have you already purchased the Salus ? They are not the most reliable
Hello,
How did you get on since I wasn’t the most helpful?
