Wiring Salus RT300 RF thermostat
14 Feb 2015
Leicestershire
I am trying to install a Salus RT300 RF thermostat I currently have a honeywell stat which has 3 wires red blue and yellow. I have connected the red a blue wire to the salus stat and it show a red light. I have tried to connect the yellow to either of the connectors on the receiver but it does not turn the heating on.
When the temperature is turned up you can hear the receiver click so that part is working but the heating does not come on.
Anyone got any ideas?
Thank you
So assuming red and blue are live and neutral and the yellow switch live
Put the yellow to NO
Put a link from live to com
Since changing the stat it seems the rads are taking longer to get hot do you have any ideas about this?
Thank you
On initial heat up, it shouldn't make any difference
Thank you for the info the problem that I am having with the stat is that it turns the heating on fine but after about 10 minutes it turns off and then after about another 10 minutes it turns back on again.
Do you have any ideas?
Thank you
How close is it to a rad etc? What temp do you have it set to, and what does the stat read?
Is your boiler upto temperature and cycling ?
I think I may have fixed the problem, I changed the RF frequency and now the boiler seems to be staying on. I am not sure if next door have the same stat but for the moment it seems to be work OK.
Thank you very much for your help thus far
