Hampshire a bit far away for me....
Didn’t need one …. Retracted EPB … then just pushed piston back by leveringbthe gap between pads & disc, moved back easily.Have you got a piston retractor tool Rick? They turn in clockwise and the proper retractor makes the job so much easier.
John![]()
Done first side this afternoon …. Took some time to get out the upper carrier frame bolt … there is little room there.Just the job, a retractor tool is only required for the mechanical handbrake system.
Did you manage to shift the bracket bolts?
John![]()
On mine, I removed the bottom shock absorber mounting bolt and moved the shock out of the way to be able to get on the carrier bolt easier.Done first side this afternoon …. Took some time to get out the upper carrier frame bolt … there is little room there.
Job done OK … other side tomorrow morning.
I did take a short drive to test … thought was in my mind.… dont do what my mate did 30 years ago……. Demolished the wall and wrote off the car![]()
Many years ago, my dad use to work in a Reliant garage. Always the butt of many jokes, the humble 3 wheelers were given a fair bit of stick - even by the mechanics who worked there. One of their favourites, was the competition to see who could get the longest wheelspin down the workshop, from a 3 wheeler. One mechanic picked up the next car out of the car park, got it to the edge of the workshop floor, revved it until the valves started to bounce and dumped the clutch...Worth doing then, and you have all that knowledge for next time. Just dont do what my mate did 30 years ago. Having changed his brakes he drove full pelt at a wall to try them out! Demolished the wall and wrote off the car![]()
