Hi, i have just bought a new built under double oven to replace my clapped out single.
The single has been fitted on a 13amp plug with 1.5mm flex which is controlled by the cooker switch on the wall.
In the fuse box there the cooker ring is still on a 32 amp fuse ( not what i was expecting for the single oven thats installed)
My qusetion is, is it just a case of changing the single plug outlet to a cooker outlet and wiring up the cooker on 6mm cable?
