Circular saw advice
Hi again.
Been doing some research and the Draper 64717 seems to be plentiful on the web; around £50.
Is this saw any better than the cheap ones like Wickes or B&Q own brand, etc, or would it make more sense just to go for the cheap ones. I REALLY don't want to spend that much at the moment, but could possibly consider it if it's worth it.
How much am I looking at for a blade for laminate? Aren't there any saws (reasonably priced) that come with one?
Thanks.
Get yourself a Ryobi, I think its the Ws6613 (Cant remember the exact model) this unit has been discontinued so you can pick one up for around £50 on Ebay. Its 1300W so plenty of power for any type of wood.
I would give the Argos stuff a miss it pays in the end to pick a decent make unless you get lucky because I'm sure somebody will reply with a " I have been using my Wickes rubbish for 3 years and no problems", its a bit like the smoker who will point out their grandad who smoked 60 a day and lived until he was 100!
Harry.
Thanks harryc.
I am a regular buyer on ebay but am a bit apprehensive getting this sort of thing from ebay, as I find it easier to deal with a retailer, etc, with regards to any problems arising.
Will look into it though, as it is a consideration; thanks.
Thanks.
a laminate blade is around £60 on its own :roll:
Ryobi over Draper every day of the week! As for eBay, there are plenty of 'proper' retailers selling new gear (with usual guarantee etc.)
eBay for blades too, I bought a 190mm trend blade (new) for a fiver last month. :D
Depending on size £40 to £65 for a good, fine tooth triple chip laminate blade (the 190mm Freud on my portable saw cost me about £50) and no, every saw maker I've ever come across supplies a cruddy 'orrible coarse rip saw blade
Scrit
Thanks big-all, Deluks, Scrit.
£40, £50, £60, £65????? You are joking, right?!
Thanks for the warning everyone!
No way I could get a saw AND a blade at those prices! Can I get away with a really cheap one just for the current job only (it's only a few inches; for the sides of the U shape to go around a wash basin pedestal)?
well a circular aint very good at going round corners :D :D :D :wink:
down cut blade in a jigsaw and a 5mm bead of mastic will hide any dammage :wink:
Nope! Chinese stuff may be allright for some things, but they still don't make decent saws for laminate work.
B-A is right about not going round corners, though :lol:
Scrit
I'm beginning to wonder if you actually need a circ saw at all :?: :?: :?:
Haha big-all; Yes I know, I know. I meant for the straight parts of the U shape as stated in my third post in this thread (last paragraph).
Ok Scrit.
Deluks, oops, I completely forgot what I originally needed the saw for! Haha. The legs, the legs; sorry! I urgently need it for the TWO purposes mentioned, but, as stated before, I will definitely need it in future for laminate boards, etc.
However, upon learning of the costs, the "sharp handsaw" suggestion is sounding more realistic (or maybe a manual mitre saw), if somewhat less appealing. Will I be able to get a perfectly straight cut in all directions even with battening (sp?)?
Thanks everyone....time to ponder....
Borrow one for the cuts, and put your £50 towards getting a better quality saw for future use. Have you ever considered the Ryobi one+ range, they do a circ saw for about£60, but it occasionally pops up on screwfix for £99 with 2 batteries/charger and 18v drill.
Hi Deluks.
Thanks for the advice.
I thought that was the most sensible option to start with, that's why I originally took the wood to a kitchen manufacturer I knew, however, as mentioned already the cuts were done in a hurry and I was left with mismatched sizes.
I also asked the person who usually carries out DIY for us, but unfortunately his old circular saw broke or something.
This is when I was left with the option of buying one myself, which I thought was a ok as I am extremely meticulous and believe that I could do a much more careful job than a professional in a hurry who doesn't really care if the work is neat or not.
I would have gone for a good one to start with but the entire budget is going to go towards buying other things for the room. I will be able to get a good saw in future, but will have to wait to come across a lucky bargain with regards to the blade!.
Are you referring to a cordless saw? If so, I don't want a cordless one; will only be using it at home; don't want to bother with all that re-charging business for a few minutes work each time.
Thanks.
Traveller said:
Hi Deluks.
it probably "broke" because he doesnt want to lend it to you. his tools are his livelehood.
I would check your definition of professional. a professional will know how to use such a tool correctly to achieve the right result, wont be in a hurry and will care about the result and his work being neat!
