click rose query.
30 Dec 2003
Im replacing the lamp holder in the loft with a florescant fitting. A friend has suggested using a click rose for the loop in wiring and then flex up to the fitting.
Can I secure the click rose on a piece of timber fastened to the floor joists with a hole for the cables to come through back entry to the click rose? and will I need a gland on the light fitting for the flex?
Or is this a bit ott??
Thanks muchly!
klik roses usually need to go on a box, so why not use a plastic thru or terminal box.
I would try to use a gland, but if the cable clipped secure a grommet would possibly ok
Yep, just use a conduit box to mount the ceiling rose on.
If you clip your cables upto where they enter the conduit box, this will be fine.
