I have struggled twice recently with leaking compression fittings.
Are these fittings now of poor quality? The merchants always say, use ptfe tape, which is not always that simple when you are up against a brick wall and behind a soil pipe.
My last fix was to buy some Boss jointing paste. I think it has stopped leaking but this shouldn't really be necessary, should it?
Later when I looked closely at the copper pipe I noticed very fine grooves down the length, probably from a faulty die in the manufacture. So the pipe quality is also suspect. Could the fine grooves allow leaking past the olives? Anybody else noticed this or had similar problems?
