Hi all,
I've got a condense pipe to run from an upstairs bedroom in a terraced peoperty, across a flat roof, and to terminate in the rainwater guttering at the end of the flat roof. As it is a terrace and each house has an almost identical flat roof, the only guttering / downpipe is at the end of the roof, running parallel to the bedroom wall which the boiler is on.
So, if done this way, my condense pipe will run around 4m along the flat roof and into guttering.
A CORGI on site doing the AGA suggested that condense pipes could be terminated ONTO flat roofs, as they are - in effect- just a big sluice to channel rainwater into the guttering at the end. He said that as they were not habitable space under normal conditions there was no risk of anyone slipping on any ice that may be formed by freezing condensate in winter.
If he is right, then I will do it this way as it will look better and save me hassle, but I'm not sure if he's trying to shaft me as he didn't get the boiler job!
Any suggestions gratefully received...
