I have a Potterton Puma 100E combi boiler that has given up the ghost and I've been getting quotes to replace it. My home has 3 bedrooms and 1 bathroom ( 8 rads and Mira excel shower).
I have had about 6 quotes - boilers recommended have included Baxi Duo Tec 28E or 33He, Vaillant Eco-tec 837, Worcester Greenstar 30 CDI).
My concern is that some (but not all) of the engineers have expressed concern that my gas supply pipe may not be big enough for one of the new condensing boilers. The gas pipe is 22mm, but there is a fair run from boiler to metre (about 14 metres with about 6 or 7 turns). There is also a gas fire and gas oven/hob coming off the supply. One guy thought it could be a real problem, a couple of others mentioned it as a slight possibility that it could cause a problem.
I have been told that the gas pipe may need upgrading to 28mm. I won't go into detail but it is really quite impractical to run a new pipe with the boiler in the same location as it is now.
My question is, are these concerns unfounded or perhaps unlikely to actually be a problem? Also, would installing a slighly smaller/less powerful boiler with a lower water rate flow help? The water flow rate of my existing boiler is fine (believe it is about 11 litres per minute).
I'd rather accept a slightly lower water flow rate if it means I don't have to replace the gas pipe, which would be an obsolute nightmare in my house.
I would appreciate your advice and thoughts.
