dont forget that any part of the gas run can be routed externally, even if it had to go a bit further it could be upsized accordingly. any rgi should be able to work out the pipe size required to ensure your new boiler works properly.
Please Tony that is rather unfair.
Not all Gas supplies need upgrading and most boilers of the type we are talking will work more than adequate of a 22mm supply(28HE - 33HE) and is why they come with that size conection.
Dont paint everyone as a cowboy because they all dont feel it needs an upgraded supply.
About half have no idea why one length of straight 22mm pipe will have a much higher pressure drop than another at the same flow rate.
I'm the guy with the meter at entrance gate 100m away.
My assumption is as it reduces into the meter the pressure will rise speeding flow but of a smaller amount but once out of the meter into the 60mm pipe pressure reduces and true flow rate will be restored. I know I am confusing flow & pressure terms but I sort of know what I mean.
I assume some loss due to friction etc. but in theory will I roughly get the same amount of Gas once clear of the meter.
What would your gut feelings be about pressure/flow at the end of my 90m's of 60mm pipe.
Thanks I/A.
