connecting a timed fan and light
3 Aug 2006
Essex
Hello
I have connected a bathroom timed fan in , i used a 3 pole switch so i can switch of the fan from outside of the bathroom.I have conected from ceiling rose to the 3 pole switch them using the switch wire to a pull cord switch and them to my timed fan.
The problem ,some where in this curcit i need to fit a light that comes on with the fan and switchs off leaving the fan to run on its timmer. can i simply connect into the same switch/connection as the fan to the neutral on my ceiling rose.
look forward to your response
are you thinking of having another pull cord light switch to bring on this second light?
so is your 3 pole switch also the light switch?
if you click on the faq third listing down scroll down half way breezer has post diagram of light with fan
he means
this one
The old to new wiring colours for this will be:
2 core + earth cable
Red = Brown
Black = Blue
Blue wire needs to be sleeved brown in the switch wire for switch live.
3 core + earth cable
Red = Brown
Yellow = Black
Blue = Grey
Black wire needs to be sleeved brown for switched live and Grey wire needs to be sleeved blue for neutral.
Hi Fireman
The 3 pole switch is only an isolater,i have copyed the drawing and give it a go in the morning
many thanks
