Conservatory
10 Jun 2009
Suffolk
I live in a Semi-detached, my neighbour has recently had a glass on three sides conservatory built on a dawrf wall, my question is, as the conservatory is only 200mm from my boundary, should the wall alongside the boundary be fire rated i.e a brick wall to the full height of the conservatory, or is what they have done compliant?
I assume the whole job was passed of by a FENSA Contractor, but i don't know for sure, and if there is a problem I want it sorted, before in later years it causes me a problem when selling my property
It's also a bit of a Dog to look at
Any thoughts or advice will be greatly recieved :?
Conservatories are building reg's exempt, though the glazing still needs to adhere to safety standards. Are there any openable lights on the boundary side?
Why don't you build a wall or a fence to screen it?
By the way, fensa registered companies are not in a position to pass jack all.
Being screwed shut is not safety compliant as any new or subsequent owners could remove the screws.
Thanks, I think i'll have a discrete word with LABC and see what their take is on it :)
The best scenario you could achieve is the openable lights replaced with solid panels or panes.
The conservatory meanwhile, will remain as will the feud with the neighbours, but with even more vigour.
Building control wont get involved as it is not controlled work - b/regs don't apply.
There is no requirement to have the windows operable, screwed shut or anything else
