hi new to site i just wondered im changing consumer unit for new one on tt system and there is a meter then tails to a volt operated earth leakage circuit breaker then from that to my consumer unit if my new board is dual rcd can i just get rid of the elcb also no earth rod well i cant find one there is a small 4mm earth cable in wall but has been cut of what size is required is it 16mm from cu to earth rod
thanks for your replys
THE VOELCB IS 60 AMP WITH BIG YELLOW TEST BUTTON
reason for change is elcb buzzes when i plug washing machine in also is very old and cracked and has no cover { very dangerous i know }
