I didn't think you needed multiple cpcs if wiring in singles, just one large enough for the largest circuit carried.
what is the topology of a cpc shared between two ring finals, or a ring final and a radial?
I still don't see why. Unless you're using conduit or trunking for the cpc it too has to be a ring. 543.2.9Dunno - I've never wired in singles - so you'd have to ask someone else. However, if one did as you suggest, one presumably could not, for example, test the continuity of the CPC in a ring final circuit.
Loop impedance, just as with a cable cpc.Mind you, with singles, I suppose that there are not necessarily any (cable) CPCs at all - it could all be conduit. In that case, it would not have to pass through any hole, anyway - but I am again uncertain as to if/how would could/would do certain aspects of testing.
cpc continuity cannot be done as per "normal".
- https://www.voltimum.co.uk/articles/guide-verification-steel-conduit
- https://www.theiet.org/forums/forum/messageview.cfm?catid=205&threadid=6205
I'm still unsure what an installation would look like if multiple circuits shared a single cpc.
