Could someone tell me the name of this fixing?
24 Feb 2007
Hi guys, I'm trying to find a fixing that can be screwed into wood that would then accept a 10mm threaded bar to be screwed within it..
I recall them having a weird name and can't for the life of me find them! grrr.
Many thanks,
Devs.
A threaded insert, maybe? these have an external RH thread with an internal thread of your choice......usually inserted tightly with an Allen key.
Its critical to drill the correct size fitting hole, and they can be a right pain if they tend to become undone when you remove your threaded screw....
John :)
Burnerman many thanks for the reply mate. I could have swore that they had a more extravagant name than that! ;)
We kept on exaggerating the name so much that non of us can remember the correct name. The most recent that springs to mind is 'muffle danglers!'
Anyway its interesting to hear your experiences with them. I plan to drill them into my pretty expensive oak staircase before bolting a very large and heavy peace of 17.5mm laminated glass to the side!
Any further thoughts or suggestions would be welcome as i'd hate to mess this one up!
Thanks,
Devs.
Great thanks for your help!
Excuse my ignorance but is the m10 the size of a bar that it would accept ie 10mm and the 13mm the length of the insert?
M10 is the size of the bolt "threaded bar" that will fit inside the insert and the 13mm is the length of the insert
The size you drill the wood to fit these is 12.2-12.5mm, dont go larger!
They look like just the ticket. thanks for all the help guys!
