Less likely but not zero, and there are four times as many of themThey are much less likely to be carrying it though.
That doesn't mean you haven't got the virus."Lateral flow tests deliver a rapid result, in 30 minutes. They can find positive cases with high levels of virus that are easy to transmit to others, helping to intercept and reduce further infections."
If you have low levels you could get a false negative despite having the 'virus'
Moral obligation cannot be forced, it's a persuasive technique.That site make no sensible argument for Covid passes other than stating is a way to get everyone vaccinated based on enforcing this theory of moral obligation - which is nonsensical to say that moral obligation has to be forced.
A Covid pass does absolutely noting to prevent the spread of Covid, unless you wear it as mask over your nose and mouth.What I'm looking for is the actual reasoning on what a Covid Pass does to help in combating the spread of Covid
But even so it seems nonsense to allow say 1000 people into an event based on a Covid Pass, and then let those same 1000 then jump on public transport, go for a drink or around the shops where no pass is needed.
ie you do it for every place and control all public interaction or none at all
If unvaccinated / untested people are not allowed in such places, there will be fewer unvaccinated / untested people socially interacting.Proximities will be closer, for longer in the first example and entry is much easier to control, with greater opportunities to be spread amongst more people.
It is much more difficult logistics involved in shops, transport, pubs and etc., with numbers much lower anyway.
As I said in the OP, the only infectious ones in such venues will be among the vaccinated ones.
But if the unvaccinated were allowed in, your condition would not apply, and the more likely is that there would be many unvaccinated spreading the virus.As I said in the OP, the only infectious ones in such venues will be among the vaccinated ones.
That can't be so. If you look at the figures for infections, a high proportion of those have to be people who are vaccinated, and Covid generally (what ever variant) will have to be spread by vaccinated hosts, otherwise it will just fade out.They are much less likely to be carrying it though.
That was the whole point of my initial question. How does it?It is the state of being qualified that reduces the spread of Covid.
NonsenseMoral obligation cannot be forced, it's a persuasive technique.
On that basis, your critique of the site fails.
How does requiring a pass to get into a venue stop the spread when the people with the pass are just as likely to be spreading the virus?
You have actually lost me. I can't understand what you are saying from your several posts.Which is exactly what it has been doing, so it's working. Unfortunately, there are still some spreading it.
So what is the benefit of allowing people into a room just because they have a pass to prove vaccination, and denying them entry if they do not?
