- Joined
- 1 Aug 2020
- Messages
- 19
- Reaction score
- 1
- Country
Hi and thanks in advance to all the givers of advice here.
I want to upgrade a Triton electric shower from 8.5kW to 9.5kW but would need to swap the existing 32a CU fuse for a 40a fuse. Is there a way for an idiot to safely tell what size the wiring is on that circuit as I gather I need 8mm for the bigger fuse and have no idea what's installed?
Also, I fear that my CU is at or near max capacity so need to check that the fuse upgrade won't exceed it. How do I find out? The board is a Wylex 1206 with a max capacity of 100amps but the aggregate rating of the fuses is over 200amps. Does that mean I'm chancing my arm if ovens, kettles, heaters, driers, laundry machines etc are all running at the same time?
(Ideally, I should probably upgrade my CU but it's in a very inconvenient place (in an internal living area from a time before house extensions were added) and would be a major engineering job to run any more wires/cables to it so I will only upgrade as a last resort.)
Thanks for any help - and apologies if my questions prove my stupidity.
