    Dismiss Notice
Cut granite block in two
Discussion in 'Building' started by kez1, 8 Oct 2018.
Tags:
  1. kez1
    kez1
    9 Apr 2012
    230
    Thanks Received:
    2
    Country:
    Need to cut granite block in two.
    It's sticking out of a wall and half needs to come off.
    Cross section is 30 cm x 15cm.
    Most cost effective option?
  2. Ian H
    Ian H
    14 Sep 2010
    7,026
    Thanks Received:
    852
    Rochdale
    Country:
    I’d try and cut it with a grinder then shear it off with a bolster.
    • Thanks Thanks x 1
  3. Sponsored Links
  4. ^woody^
    ^woody^
    3 Sep 2006
    32,948
    Thanks Received:
    4,453
    West Mids
    Country:
    Use a spoon like Clint Eastwood did in Alcatraz.
  5. kez1
    kez1
    9 Apr 2012
    230
    Thanks Received:
    2
    Country:
    Thanks Ian,
    I got this standard size grinder disc: Spectrum DX10 Turbo Diamond Blade 115 x 22.2mm
    https://www.toolstation.com/shop/Po...1450/Spectrum+DX10+Turbo+Diamond+Blade/p67488
    from toolstation for £13.98.
    It allowed me to cut 2cm deep all the way around the edge of the granite block.
    Then a few hard taps with the large demolition hammer and it just sheared off.
    Nice clean break, just as desired.
    This disc cut into the Aberdeen Granite with ease and without apparent wear to the disc.
    I've never cut granite before and I'm astonished at the ease with which this blade and my standard size small angle grinder cut into it.
    Didn't really have to apply much pressure and the blade just cut in.
    Didn't need to use water either.
    If you want to cut into granite up to 2cm deep with your standard size grinder this blade does a fantastic job.
    • Like Like x 1
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
