Cutting Concrete Reinforced Foundations
13 Jul 2017
Greetings all
Currently removing part of our house to sell off the land to a developer.
Demolished part of the house but am retaining part of the piled foundations and reinforced ring beam. Structural Engineer has recommended that we cut the foundations using a diamond saw instead of a kango as the vibrations weaken the part of the ring beam that we wish to retain.
Has anyone any experience with concrete cutting? Any suggestions s to how its done? Is this something that I can do myself?
Many thanks
Robert
Ha thanks for that.
I didn't phrase it well enough. What type of saw do you use?
I have seen it done in Switzerland, they used a specialist contractor who provided and operated a diamond saw (they also exist in UK)
I noticed they used a wet-cut, water and fine powdered concrete slurry was running out for hours.
Where a "plug" was to be removed, they drilled it first and used a supporting steel jig to take the weight of the plug before starting the cut.
I have also seen it done by stitch-drilling, but that didn't look as good.
The piece of concrete you cut, if unsupported, might fall out and damage the operator or equipment.
You can see a recent example if you google "Hatton Garden Heist"
http://i4.mirror.co.uk/incoming/art...-through-a-half-meter-thick-concrete-wall.jpg
Petrol saw/ Stihl saw with diamond blade.
As the blade is only 300mm wide, with just over 100mm depth of cut, you will need to cut a slot, then chip some concrete away in a gradual process to allow the saw blade (and saw) to go through all the concrete. Otherwise you are in the realms of a larger specialist saw and massive costs. But if the developer is paying, that won't matter.
A ring saw will give you about 200mm cut depth. You can hire a floor saw if you have long deep cuts. Standard size will give you around a 165mm cut you can go as big as 350mm quite easily from some hire places.
