Agreed.It would be worth the op seeing if there is a joint just above the light fitting, perhaps in connector blocks, just in case there happens to be a bad joint there ...
I'm pretty sure that it has never been confirmed, hence reinforcing the point above. Indeed, the fact that 'hitting the wall' has an effect could just as well be due to bad connections in a hidden JB as to a 'damaged cable'. I wonder if the OP has tried 'hitting the ceiling'?- as I'm not sure if it was ever confirmed if the cable actually was damaged in the wall.
Kind Regards, John
