Danfoss TP4000 to Hive
M
mrsarcysean
Hi Guys,
I have a Hive Active Heating and a separate Multizone ready to install. I am fairly confident in the way it works just unsure which wires to put where as I appear to have numbers 1-12 on my back plate currently! Any help would be much appreciated :)
Nice pictures of the wiring centre, but unfortunately they don't help. That part of the installation will stay as it is. The controls are what you will be replacing i.e. programmer, thermostats etc.
You will need to find the wiring diagrams for your existing controls (programmer & thermostats). From that you will be able to see what each of their terminals function is. Then from that you will know what each wire connected to them is actually doing Then by looking at the Hive manual you will be able to see the corresponding terminal on the appropriate Hive receiver and move the wires across to the terminals that have the same function.
