- Joined
- 16 Oct 2021
- Messages
- 683
- Reaction score
- 74
- Country
lolor buy a switch that does have PoE on all ports....lol
Only one device assigns IP addresses. If there are two devices which can do that, it's disabled on one of them.so if the router assigns a local address to all devices and then you have the camera box assiging their own local addresses,
so if the router assigns a local address to all devices and then you have the camera box assiging their own local addresses, how do you manage conflicting addresses? If as you suggest, they operate on a different subnet, how do you access the camera feed from your primary network? e.g. how do I see traffic on 102.xxx.xxx.xxx on 192.xxx.xxx.xxx ?
WOW...i hope this is just advice and you don't actually try and do any of this lol. Your knowledge is not just limited, its just simply not trueSome DVRs/NVRs have two ethernet ports. One is assigned an IP address by the router. The other port is used to set up a separate IP range for the cameras. The advantage of doing so is that it reduces traffic on the primary network.
You can see data in other IP ranges. Any given website will be on a completely different ip range to most home owners.
For full size ones, there are still UK manufacturers, but for wall mount they are pretty much all the same, imported from China.Is there a preferred manufacturer of data cabinets
no its not what you said actually.Care to apologise?
Hikvision DS-9632NI-I8, one of many NVRs with dual NICs
There is a discussion about it here
Q. "Hello all I just purchased a Hikvision DS-9632NI-I8 NVR upgrading from a DS-7616NI-K2-16P NVR and I am a little confused on the setting up of the two Lan ports and the advantages and/or disadvantages of each configuration. I currently have 12 IP cameras running through three separate switches that then connect to my router and three cameras that run directly out of the poe ports on the back of the NVR."
https://ipcamtalk.com/threads/hikvision-dual-lan-ports.52586/
A. "It gives you some flexibility for distributing the cameras around the network in a way that suits requirements, for example so that you could have a physically separate camera network, and still have the NVR accessible via the 'normal' network." In reply to the mention of running all of the cameras trough the router- here is the reply "Hopefully not passing camera traffic through the router to the NVR or to a monitoring PC.
Some routers don't handle high volumes of camera traffic well, it can impact their primary task - routing."
Which is pretty much what I said...
Oh.. and in the past I used to have a HP business inkjet printer that had the useby date hard coded in to the inkjet cartridges. I set up an old PC to run as a Linux print server. It was on a different IP range to the rest of my network. All I had to do was tell each PC in the other network what the IP address of the printer is.
I may well have forgotten much of that I learnt, but I learnt enough to know that the OSI model has 7 layers and the the TCP?IP stack has 4. I used to maintain my own webserver. I have more than a passing knowledge of DNS, RDNS, MX records, SSL certs and so on.
there is a method of being able to access data from different sub nets using a router as a gateway between them. This requires a setup beyond the average understanding and its certainly never a plug and play option.
