to choose working to the current edition of the Wiring Regulations as their method of compliance.
AIUI it is possible to comply with regs (in the context of bathroom wiring) without RCD protection - another being cross bonding. But using RCD protection is an easy way to comply.
Are you being deliberately obtuse?
Choosing to comply with the current edition of BS 7671 is the easiest way to comply with the law
and AFAIK it is the only way open to registered electricians.
Once chosen then effectively it does become a legal requirement to comply with BS 7671.
actualy they state they found a real gas leakThey fake it - there wasn't a real gas leak, so how could they have broken any gas regulations?
Well, you are being obtuse, so if it isn't deliberate then it is because you are genuinely mentally slow.Are you being deliberately obtuse?
No,
Yes, I know that.I'm pointing out that there is no obligation to follow BS7671, as you well know.
It might have become true via the choices made by the electrician for the way he complies with the Building Regulations.A little way up the thread you stated that it's "100% unacceptable" for that company quoting for the bathroom work to tell the a customer that it would be illegal without fitting a new consumer unit.
Do you not consider it equally unacceptable for an electrician to try and tell a customer that there is a legal requirement for all new work to comply fully with BS7671 even though that's not true?
ButBut not the only way. Even the guidance notes acknowledge that.
As a condition of their membership to the scheme, yes. But that's the not the same thing as them trying to suggest, or at best imply, that it's a legal requirement.
There is for someone who uses his membership of a Competent Person scheme to avoid having to give a building notice or deposit full plans.What do you mean by effectively, exactly? There is no legal compulsion to follow BS7671. Period.
Then what are you arguing about?Yes, I know that.
Er, no...... If somebody chooses to follow BS7671 then that's almost certainly going to be accepted as being compliance with the legal requirement of Part P. It can't suddenly create legislation which makes compliance with BS7671 a statutory requirement in itself.What you seem unable or unwilling to accept is that [if] somebody chooses compliance with BS 7671 as their route to compliance with something which is a legal requirement then they have chosen to make it a legal requirement for them to comply with BS 7671.
having chosen it, and officially declared that it will be the way to compliance with a requirement which is required by law, then you have to comply with it.
[If] they are using their membership of a Competent Person scheme as the way to be exempted from the requirement to give a building notice or deposit full plans, and they then contravene the terms of their membership of that scheme their claim for exemption from Building Regulation 12(2) is without basis.
Only indirectly because all of the schemes require members to work to BS7671. Hence my earlier comment about misleading untruths above.There is for someone who uses his membership of a Competent Person scheme to avoid having to give a building notice or deposit full plans.
It's not just modest displays either !P.S. Do we have to have 1800-pixel wide "IF" images? For anyone using more modest displays they're far too big to be seen as a whole and just result in having to scroll back and forth horizontally down the entire page to read the posts.
Not his only goal, but I'm pleased for him that this seems to be one of his goals that he has succeeded in realising!But you know the answer to that question - this is BAS we're talking about and his goal in life seems to be to annoy as many people as he can.
It seems that even when I repeated the IF, as in IF someone makes it his way to comply with the law then he has made it required by law, as large as I could, you still refuse, or are unable to see the word or to recognise its presence in a logical progression.What is obtuse about it? I've simply pointed out that there is no statutory obligation to comply with BS7671. That's a simple fact.
I wasn't arguing - I was trying, (in a ridiculous triumph of hope over expectation, given your track record) to get you to understand a logical series of consequences.Then what are you arguing about?
1) A customer has chosen to have the work done by a registered electrician.Perhaps so. But that still doesn't make it acceptable to tell a customer that compliance with BS7671 is mandatory. Such a claim is still incorrect, and unacceptable.
Apparently it's not.P.S. Do we have to have 1800-pixel wide "IF" images? For anyone using more modest displays they're far too big to be seen as a whole and just result in having to scroll back and forth horizontally down the entire page to read the posts. Come on, bold and a few point sizes larger is quite adequate to emphasize a word.
Oh look - another member of the hard-of-thinking club.Not his only goal, but I'm pleased for him that this seems to be one of his goals that he has succeeded in realising!
The sad thing is that you clearly have the potential to make very valuable contributions to this forum, but you make it so difficult to see those trees through the wood. My fear is that the day may come when your perceived effects on the image of the forum (particularly in the eyes of newcomers) reaches the point at which your opportunity to make valuable contributions becomes curtailed.Oh look - another member of the hard-of-thinking club.
