P
Paul_C
1) A customer has chosen to have the work done by a registered electrician.
2) The registered electrician is required by his scheme to comply with BS 7671.
That does not make it acceptable for the registered electrician to lie by telling the customer that compliance with BS7671 is a statutory requirement.
It would depend upon the contract terms.3) If the electrician does not comply with BS 7671 he is not providing his customer with the service the customer contracted for.
Not disputed. But that does not make it acceptable for him to lie about the statutory requirements.4) If he does not comply with BS 7671 he is no longer entitled to avoid applying for Building Regulations in advance because he is no longer working to the standard required by the organisation which would allow him to avoid it.
That still does not make it acceptable to lie about the statutory requirements.5) For him to provide the service contracted by his customer (surely a legal requirement?) and for him to legally avoid advance notification he has to work to BS 7671.
6) Failing to work to BS 7671 results in breach of contract and contravention of the Building Regulations.
I'm not talking about a specific case where the work does not comply fully with BS7671 but is not notified etc. I'm talking about the general issue of a registered electrician deliberately giving incorrect information about the nature of the statutory requirements. If he tells a customer that all work must comply with BS7671 by law, then he is misleading that customer, just as the bathroom company earlier telling a customer that a new consumer unit is a legal requirement for the planned work is misleading that customer.And you don't think that for that particular electrician for that particular job the fact that failing to comply with BS 7671 results in both civil and criminal offences makes complying with it a legal requirement?
And even if we do consider your specific case quoted above, assuming that the non-BS7671 compliant work was still reasonably safe, then the only offense would be failing to notify the work in advance, not a failure to comply with the provisions of Part P.
