Hi all,
We have had an extension done and have recently knocked through and put in a large steel.
The builder (and project manager) has put the steel on a padstone and the padstone is suspended across the two leaves of the cavity wall. The cavity wall that it is sat on used to have a closed face as it was a nib/return that we cut back to reduce the amount it stuck out. Now the cavity is exposed.
Building control said that this is not acceptable and the SE has also agreed that it is not acceptable and that his calculations were based on that return being closed. He specifies in the Calculations the following:
Inner Leaf: assume Blockwork = 3.6 N/mm2
Assumed full bearing on cavity wall
Try End Bearing = 150mm (minimum)
Steel Beam <B1>, 203x203UC, steel ‘in-plane’ of wall
The builder is saying it is not his fault as he has built it to the calulations and has 150mm bearing and is refusing to resolve the issue at his cost.
I feel that 'assumed full bearing' means that the padstone is not suspended between two cavities but is fully resting on something and has no void underneath it.
Am I correct in this? I am now stuck between two professionals claiming it is not their problem.
Ultimately the builder has also been paid a management fee, so I feel that the buck should stop with him to get his work signed off by building control.
Any thoughts and advice would be much appreciated.
