I do not believed that I ever referred to a TT situation.it seems that you've probably been making comments which are not relevant to UK, and which may well confuse people in the UK. To suggest/imply (to readers in the UK) that the only purpose of a local earth electrode in a TT installation is to offer some protection against 'voltage surges/spikes', is really pretty misleading - since it could be taken to imply that there would be no true safety (to human beings) concerns if an installation had no 'earth' at all.
I think that TN-C-S has been around for less than 50 years in UK, I think starting to be implemented significantly in late 1970s and early 1980s. Prior to that, all installations were either TN-S or TT, and a substantial proportion of those (like my TT installation) have not been 'updated' to TN-C-S as of today.
(It is "interesting" that you refer to previous installations being "updated" to TN-C-S,
which is [perhaps] an indication that other installations, such as yours, were more "primitive".
See https://en.wikipedia.org/wiki/Earthing_systemn
"A big disadvantage of TT systems is that the impedance of the earth path is often so high that it can prevent overcurrent protection devices from breaking the supply sufficiently quickly to meet safety regulation.")
In the original Post was this:-
I have no idea concerning the "Local Regulations" on this point.We currently have a powered shed with its own local RCD and MCB protected fusebox for lights and sockets (which also feeds an outdoor socket a few metres away in the garden).
The shed (and outdoor socket) is currently earthed using the house earth, which is on a TN-S setup, which was commented on (i.e
told it was "not ideal") by the last electrician we had out to do some work.
Is this setup a safety issue, and will it fail the EICR under current standards if I don't get a local earth rod fitted (assuming everything else is OK)?
However, installing a additional "Earthing Electrode" on the PE of a TN- S system at an "outbuilding"
would (to me) seem to provide the same "local" (low impedance) "surge protection" as that is required on TN-C-S systems
in both Australia and North America,
as is discussed (at length) in the video concerned.
Such precautions may not be considered to be necessary in closely settled urban areas of the UK,
where there may be much other higher infrastructure on which "lightning events" may take place
and
there may be few such "events".
In both Australia and North America
with "wide open spaces"
and
where "lightning events" are not uncommon,
such near-by bonded Earthing Electrodes are necessary and required.
