Door not taking paint? Wood still damp?
  • Thread starter Thread starter ODB
  • Start date Start date
ODB
28 Mar 2006
London
Had my front door dipped and stripped about 2 weeks ago and thought with all the dry weather it would be ok to primer as I've been filling bits in here and there. It's an original door, must be about 100 years old.
However, after I whacked a quick coat on I had a patch like this:
As you can see it discoloured and is still a bit soft (I used water-based primer).
I've taken the paint off it, could it still be damp? Even after it hasn't been touched with water in over 2 (dry, and mostly hot) weeks?
If so how can I speed it up drying out? Any help/advice appreciated!
May still have stripping agent in it after dipping, dipping ruins doors, removes all natural oils and with an exterior door it will absorb moisture very easily and warp or even fall apart. :cry:
The section in photo looks like it might actually be rotten, if you can push a blunt screwdriver into it then this is probably the case.
Aaaargh!
Wish I knew that before getting it stripped.
Will just have to leave it out in the open for a bit longer. Luckily it's under a porch so hopefully it won't fall apart too soon :(
Thanks for the tip anyway, much appreciated
I think there must be some resin in the wood that is seap[ing out. To stop this happening a coat of a white shellac based primer like Smith & Rodger Multiseal will do the job.
It's excellent a sealing in any old 'nasties' prior to painting.
Hope this helps
Had the same probelm with a door that i had dipped. Dipping is caustic and if not washed off properly will come out later in the paint. Oil based undercoat may still not seal it. Zinsser Bin 123 was used and this stopped it. As mentioned, Shellac based sealers usually do the trick.
