Doorbell issue
3 Feb 2024
Cambridgeshire Fens
We live in an old Fenland farmhouse and our back gate, where the post and most deliveries arrive is - in a straight line - about 30 metres from our back door. Unfortunately, there is an old brick-built tractor shed, which we use as a garge/potting shed, directly between the house and the gate which impedes any wireless doorbell signals. I am currently on the third bell kit, a Technet unit with a supposed range of 400 metres, but it still only works intermittently, and more often than not we rely on the dog to hear the postman arrive, much to the ongoing consternation of said postman! It is frustrating to miss deliveries, which then have to be re-arranged or collected from the nearest delivery office, which only opens for 1 hour, on three days when there's a z in the month.
I am wondering if there is any way to enhance or improve the signal so that it will pass through, around or over the shed and actually activate the ringer unit in the house. The only alternative as I see it is to install a wired system on a mains-powered transformer, which would mean digging a trench to lay cable ducting. Given the distance, would I still have any issues with power loss through the bell wire, considering the comparatively low voltage of such a system? There is electrical power in the tractor shed, where a bell transformer could be installed.
Any thoughts?
Would it though? Why do you need to bury the cable?
But you have a building with power in it, with short line of sight to the house, and short line of sight to the gate. Must be a way to link the two inside the building?
Would a wireless repeater or range extender on the outside of the shed resolve the problem. Speak to Technet.
There not cheap but look at wisebox, you would need 1 in the shed 1 in the house, 1 external bell push and 1 standard bell set up in the house.
Cant quarantee it will work but maybe an option.
Though to be fair you can get the receiver bits etc and transmitter bits and maybe build your own cheaper
They offer a range of systems, one self powered push, able to work at 1300 feet. https://tecknet.co.uk/products/tecknet-self-powered-doorbell-with-3-receivers
You could fit two receivers in the house, the other in the shed audible at the gate, for feedback to the postie etc. Generally, the higher the transmitter and receivers are mounted, the better the reliable range, so if you fitted one of the two upstairs, it might work better.
These doorbells usually work on a frequency of about 433 MHz.
Inside the "bell-push" unit there is usually a printed circuit board with an "antenna" -
being a circuit board "track" connected (soldered) only at one end - usually along the long side of the unit.
Because of the size of the unit in which this "antenna" is located, this antenna is not long enough to be actually resonant at the frequency involved.
If you can open up the bell-push unit and find the connection point of this internal "antenna",
it should be possible to solder a length of wire to this point and allow it to hang down below the installed .unit.
This length of wire should be cut to 133 mm (or, as close as possible to this) to be resonant at 433 MHz..
This may allow the bell-push to transmit a stronger signal.
And the same it true for the receiver.
